Ansys Learning Forum Forums Discuss Simulation Fluids Simulate Thermal Equilibrium Using ANSYS Fluent Reply To: Simulate Thermal Equilibrium Using ANSYS Fluent
sebastian.maluenda.m
I simulate in Fluent because not all PCM properties can be simulated correctly in Mechanical, however I do not consider buoyancy since it is an ideal system. Therefore I would like to know how to simulate thermal balance in Fluent, or at least know what conditions the walls must present for heat transfer to occur, and consequently, a loss of system temperature.
