Ansys Learning Forum Forums Discuss Simulation Fluids Modelling porous material Reply To: Modelling porous material
What errors are you seeing? Remove sections of code until it works, ie set any/all values as constants & test, then one equation at a time.
Common mistake - did you assign UDM in the solver?
