Ansys Learning Forum Forums Discuss Simulation General Mechanical Nonlinear analysis problem Reply To: Nonlinear analysis problem
Akshay Maniyar
Hi Brian,
It looks like your model is not converging. Can you request Newton-Raphson residual plots and check which is the problematic location? As per your description, the issue might be in contact between the strip and the remaining geometry.
Thanks,
Akshay Maniyar
