TAGGED: fluent, pcm-charging-discharging, porosity, porous, udf
October 17, 2023 at 5:56 pm
Robbie Crosby
SubscriberHello, I am trying to create a UDF to fit a numerical model which must be applied as UDFs in ANSYS Fluent to model a phase change material in a porous medium. I have attached the mathematical model I am trying to follow as well as my current code. I am currently stuck on getting the interstitial heat transfer coefficient to come up as a UDF, that can be selected in ANSYS Fluent, for the non-equilibrium model of porous medium. Any help would be greatly appreciated. Should it be define_profile or define_property
#include "udf.h"
#include "mem.h"
#define Tsolidus 300.0
#define Tliquidus 304.0
#define L_f 250 //Latent heat of fusion
Â#define UDM_RHO_F_PREV 0Â // UDM index for storing previous rho_f
#define UDM_LAMBDA_PREV 1Â // UDM index for storing previous lambda
ÂDEFINE_PROFILE(h_sfq, c, t)
   real dl, epsilon, mu, nu, pr, rho_pcm, u, v, mu_pcm, k_pcm, Re_d, h_sfq, local_h_sfq;
   cell_t cell;
ÂÂ Â Â dl = 0.0194; //Diameter Matlab
   epsilon = 0.85; //Porosity Matlab
   mu = C_MU_L(c, t);       // Laminar viscosity
   rho_pcm = C_R(c, t);         // Density
   nu = mu/rho_pcm;            // Kinematic Viscosity
   pr = nu/rng_alpha(1., mu, mu); // Prandtl Number
ÂÂ Â Â u = C_U(c, t);
   v = C_V(c, t);
   mu_pcm = C_MU_L(c ,t);
   k_pcm = C_K_L(c, t);
ÂÂ Â Â Re_d = (rho_pcm * sqrt(u*u + v*v) *dl) / (epsilon * mu_pcm);
ÂÂ Â Â if (Re_d > 0 && Re_d <= 40)
       local_h_sfq = (0.76 * pow(Re_d, 0.4) * pow(pr, 0.37) * k_pcm)/dl;
   else if (Re_d > 40 && Re_d <= 1000)
       local_h_sfq = (0.52 * pow(Re_d, 0.5) * pow(pr, 0.37) * k_pcm)/dl;
   else if (Re_d > 1000 && Re_d <= 20000)
       local_h_sfq = (0.26 * pow(Re_d, 0.6) * pow(pr, 0.37) * k_pcm)/dl;
   else
   return local_h_sfq;
October 27, 2023 at 11:31 am
Atharva Nagarkar
Ansys EmployeeHello,
The DEFINE_PROFILE macro is used to define a custom boundary profile or cell zone condition that varies as a function of spatial coordinates or time while you can use the DEFINE_PROPERTY to specify a custom material property in Ansys Fluent for single-phase and multiphase flows. Based on this, the DEFINE_PROPERTY macro would be more suited for your use.
Please find the links from the Ansys UDF Manual related to both these macros. Check sections 2.3.29 and 2.3.30. I would also request you to have a look at the examples given below these sections to understand the use of these DEFINE macros.
2.3. Model-Specific DEFINE Macros (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thanks!
- The topic ‘UDF for Interstitial heat transfer coefficient in non equilibrium porous media’ is closed to new replies.
