October 29, 2018 at 6:29 am
October 29, 2018 at 4:22 pm
Sandeep Medikonda
Ansys EmployeeHi, It is not necessary and maybe I don't quite understand your question completely but, what's the point of using Orthotropic Elasticity if you are not modeling Orthotropic Behavior? You might as well use Isotropic Elasticity, that would mean the same thing?
Please take a moment to look at this section from the help.
Sandeep -
October 30, 2018 at 3:07 am
dayahsaidon5566
SubscriberHi,
Before this I'm using the isotropic elasticity in my modal analysis but I'm facing a problem on tuning in the simulation to actual parts (frequency and deflection modes). And after some researched and discussion, it shows that copper is highly anisotropic and it is recommended to use orthotropic elasticity.
Now, I'm facing a problem on deciding the orientation of the copper.
October 30, 2018 at 11:37 pm
Sandeep Medikonda
Ansys EmployeeAren't these the miller indices for crystal lattices? How is the paper calculating these? Is it experimental?
Since you are dealing with macroscale properties based on continuum mechanics in FEA, why not average out (columns) each of these planes, i.e., (abc) Orientations 1 to 11 and use those as the orthotropic properties for your material?
Sandeep
Guidelines to Student Community
- The topic ‘Orthotropic Elasticity’ is closed to new replies.
6465
