Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Seeking clarification on coefficients in kw-BSL/SST model › Reply To: Seeking clarification on coefficients in kw-BSL/SST model
Thank you for the reply SRP!
Although there appears to be a communication breakdown between us. I am saying that alpha_infty is not a constant in the BSL and SST models.
Equation 4-110 in section 4.4.2.4.2 states the correct equation for alpha_infty: k-w BSL (Production of w) — It’s not a constant. In fact the line above the equation is very clear to point out this difference between the standard and SST/BSL formulations.
However I see the link that you sent clearly states that alpha_infty is a constant and its value is the same as the standard k-omega model.
So which is it?
