October 12, 2023 at 12:11 amFrancisco LoteroSubscriber
I do not understand the following error, I made a body with a thickness of 2mm and 2.2mm, then I applied midsurface with a range of 20mm, all this I did in space claim, and now I get this error in Design modeler to make the control volume applying boolean
I would like to understand the reason for this error and how to solve it.
October 13, 2023 at 12:55 pmAshish KhemkaForum Moderator
Please see if the following links help:
ANSYS FLUENT – Operation would result in non manifold bodies
Ashish Khemka
- The topic ‘I do not understand the error’ is closed to new replies.
Ansys Innovation Space
- acces to path ‘session_files’ is denied error
- Fluent and Rocky DEM coupling in Ansys student
- Error: Result file is incomplete or corrupt. It cannot be read.
- ANSYS 2024 R2 Student License Manager Error
- JavaScript Runtime Error in AQWA Pre on Windows 11 (Version 24H2)
- unexpected license problem; exiting. hit return to exit.
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys MAxwell student data e4xport
- My Ansys Workbench is opened but not displayed on my monitor
- Script Error while opening Ansys Mechanical
599
591
591
366
