Need a tutorial for solidification model.
    • rumth
      I need a tutorial for solidification model. Consider a "L" shaped pipe which is filled with liquid. How can I solidify the liquid? The fluid is flowing due to pressure drop.
      Raju.
    • Keyur Kanade
      May be following help you .
      Keyur
      https://www.youtube.com/watch?v=4qTnt0B3dOY
    • seeta gunti
      Another tutorial on Metling and solidification.
      https://www.youtube.com/watch?v=rn6YZwv_lZE
      https://www.youtube.com/watch?v=5_MKJSRd6jQ
      Seeta
    • sandeepruchi93
      Hello sir/madam
      This tutorial is not helpful in my solidification simulation analysis. When we revolve the geometry it's is in solid form but after slicing from one plane it's like a surface only. At the start of the setup procedure, it's showing some error and not start the setup procedure.
      Please explain the procedure in brief to understand the video. Your reply helps me to improve my simulation.I'm eagerly waiting for your reply.
      Thanks a lot in advance
  • The topic ‘Need a tutorial for solidification model.’ is closed to new replies.
