Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › nCode Surface Change (Polished,Ground..) › Reply To: nCode Surface Change (Polished,Ground..)
October 9, 2023 at 8:15 pm
louiee1907
Thank you, sir. I have broken the 'material map from WB' and the analysis is solved
