TAGGED: -user-defined-results, 2021-r2, solution-combination
October 9, 2023 at 9:00 am
aecm20
SubscriberI have a study with multiple loads applied in individual static structural systems. For bolt analysis I want to get the reaction force across a contact. I am using the solution combination tool to combine the loads into various load cases. Using 2021 R2.
The problem I have is that the colution combination tool doesnt have a force reaction result option. I can set the geometry to a surface and use the user defined result tool with ENFOX, Y or Z to get the elemental nodal forces. If I export and sum these (for each node) I get the right output, but only at one solution combination. I have 26 load cases and 12 surfaces though so doing this process manually is not practical.
Is there a way to sum the elemental nodal forces within the expression line so it gives a total force maximum instead of the macimum nodal force.
Things I have tried; sum, identifiers, ENFOVECTORS, submodelling.
Maybe this is within the user manual but I cant see it anywhere.
All help much appriciated.
October 11, 2023 at 4:25 am
mjmiddle
Ansys EmployeeSolution combination and Design Assessment will not allow probes. A “DA Result” under a “Design Assessment” system has a “Sum Results” that should do what a force probe result would, but it is unsupported, and I can’t get the DA Result to work for anything anymore.
You would need to use scripting by some means. Either script in Mechanical or APDL:
Method 1:
Run script in Mechanical in “Automation > Scripting”:
# First create force probe under each analysis containing the text "for_combination"
# Then run the script below
sumResultX = None
sumResultY = None
sumResultZ = None
for analysis in ExtAPI.DataModel.Project.Model.Analyses:
# Solution Combination is limited to static structural systems, so lets do that too
if analysis.AnalysisType == AnalysisType.Static:
probes = [result for result in analysis.Solution.Children if "for_combination" in result.Name]
if len(probes) > 0:
probe = probes[0] # use 1st one
if sumResultX == None:
sumResultX = probe.XAxis
else:
sumResultX += probe.XAxis
if sumResultY == None:
sumResultY = probe.YAxis
else:
sumResultY += probe.YAxis
if sumResultZ == None:
sumResultZ = probe.ZAxis
else:
sumResultZ += probe.ZAxis
print("X Axis: " + str(sumResultX))
print("Y Axis: " + str(sumResultY))
print("Z Axis: " + str(sumResultZ))Method 2:
Use APDL script. This involves loading results of each analysis and then using load case commands. Generally:/post1
file,file1,rst ! Start with first results file
set,1,1 ! Read into memory load step 1 substep 1
file,file2,rst ! Switch to second results file
lcdef,1,1,1 ! Assumes 2nd result is load step 1 substep 1
!insert any lcfact commands
lcoper,add,1 ! Add results together
cmsel,s,my_named_selection
FSUM,,BOTH
*get,my_fx,FSUM,0,ITEM,FX
*get,my_fy,FSUM,0,ITEM,FY
*get,my_fz,FSUM,0,ITEM,FZ
or
reswrite,file ! use new file name since it can append to a pre-existing results file.
Load results in Mechancial and view there using “Tools > Read Results Files…”
Make sure you select the correct units the solution was ran in.
You may get an error, “An unknown error occurred during solution.” But the solution should be correct.
- The topic ‘User defined result to combine force reactions in solution combinations’ is closed to new replies.
3266
1031
984
859
798
