October 7, 2023 at 7:01 am
zcs19991114
Subscriberhello
I want to create a permanent static magnetic field over the whole region while using transient solve.Could you tell me how to achieve it?
And I have another question.I built a coil ,and set a terminal.When i use the current source to drive it,i find the current is distributed unevenly around the coil. What's wrong? -
October 12, 2023 at 2:48 pm
GLUO
Ansys EmployeeHello,
- Please use helmholtz coil to create the field in transient solver.
- It seems like there is eddy effect on this coil. Please use stranded round-shape coil and make the solution region larger.
GL
October 13, 2023 at 8:07 am
zcs19991114
Subscriberthank you
October 30, 2023 at 7:32 am
KANTUBHUKTA HEMANTH HARI KISHORE
SubscriberHello GL,ÂÂ Â Â Â Â I hope this email finds you well. I am writing this to seek your assistance regarding an issue that I am facing while doing Transient analysis, for a tube(100mm length) and a coil placed inside the tube, in ANSYS Maxwell. There are two such models are shown, viz.Â1. Single Stage - tube and middle coil.2. Multi Stage - tube, middle coil, and two end coils(connected in series).ÂFor the excitation of coils, I've used a current dataset obtained from an experimental setup.ÂThe magnetic field along the inner surface of the tube (i.e., along distance at a particular time) is unsymmetric and has more ups and dips even though my modal is symmetric. I've shown the magnetic field distribution for both models.ÂWhy is it unsymmetric? I want to get a peak at the center and symmetrically reducing curve to either side.ÂI would greatly appreciate it if you could assist me in getting a symmetric curve.ÂÂÂ
- The topic ‘how to to create a permanent static magnetic field while using transient solve’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1241
1118
1015
