October 21, 2018 at 3:59 pm
rajdipjag
Subscriberi am having doubt that, in spaceclaim that how to convert sketch into the surfaces?
October 21, 2018 at 8:20 pm
peteroznewman
SubscriberIf the sketch is a closed profile, when you click the 3D mode button (the solid cube icon on the bottom edge), the curves will be replaced with a surface that can be pulled into a solid.
October 22, 2018 at 6:50 am
Keyur Kanade
Ansys EmployeeHi,Â
Yes, as Peter has mentioned, once you switch from 2d to 3d, SpaceClaim will create surfaces.Â
Are you importing any sketches? Does it have curves? Are you importing images?
Keyur
October 23, 2018 at 4:11 am
Keyur Kanade
Ansys EmployeeHi,Â
Is your issue resolved?
Keyur
- The topic ‘surfaces from sketch’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
1487
1338
1188
