October 3, 2023 at 11:19 am
m.belchovski
SubscriberHi,Â
I have a problem when trying to set up a single parameter sweep for my CW laser optical power in INTERCONNECT. As you can see from the picture below, where it is shown how I set my sweep, I set the starting point of the sweep -10 dBm to 0 dBm. But when I run the sweep, I get the following error: "Error: prompt line 1: in setnamed, the value supplied is not acceptable for the property 'power', it may be out of range, have incorrect dimensions or not be found in the list of choices ". When I put value from sweep from 0 to 10, it works normally.
How can I solve this problem?
Thanks.
October 3, 2023 at 11:25 am
m.belchovski
SubscriberOr the sweep start, and stop should be in absolute power units (W)? -
October 3, 2023 at 7:20 pm
Dev
Ansys EmployeeHello, Please try power in W (SI units) not in dBm.
Thanks and regards
Devika
- The topic ‘Parameter sweep of optical power in INTERCONNECT’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Import material .txt file with script
- Absorption cross-section of AuNR excited by prism-based TIR
- How to measure transmission coefficients on a given plane .
- TE Polarization Fraction + Waveguide TE/TM Fraction
- Edge Coupler EME Example Issue
- Lumerical Python API Topology Optimization Error 2025 R1
- 2D inverse design grating coupler
- FDE : Simulation waveguides with electrodes
- Loss of lithium niobate phase modulator
2427
930
599
591
569
