October 18, 2018 at 2:03 am
xmnnd
Subscriber Hello, I have a problem here on my Ansys 19.2. The allowable cores for our license should be 16. However, I can only use up to 4 cores on my computer. Once I change the setting to more than 4 cores, it does not compute and gives an error. Also, if I enable the GPU, it doesn't compute no matter how many cores I want to use. Does anyone have suggestions?
Thank you.
David Ma
October 18, 2018 at 4:57 pm
tsiriaks
Ansys EmployeeHi David,
It sounds like you are using a non-academic license.
Please open up CMD Prompt then change directory to
ANSYS IncShared FilesLicensingwinx64
then issue this command
ansysli_util -checkout ANS_SOLVER
and post the screenshot of the output here.
Also, open Client ANSLIC_ADMIN Utility 19.2 > View Status/Diagnostics > Display the License Status >Â post the output here.
Thank you,
Win
- The topic ‘Ansys running on up to only 4 cores’ is closed to new replies.
3757
1333
1168
1090
1014
