Ansys Learning Forum Forums Discuss Simulation General Mechanical Unable to edit Mechanical Contour Legend Reply To: Unable to edit Mechanical Contour Legend
Sampat Kumar
Hi Andrew,
If you uncheck Max, Min on Color Bar, you can set the highest value to a value larger than the maximum and the lowest value on the legend to a value smaller than the smallest to get consistent numbers on every plot, but you can not decrease the max value, and cannot increase the minimum value.
Please follow the following link that might be helpful for your queries.
I appreciate that you are using Ansys and please feel free to post questions here, will try to help you as soon as possible.
/forum/forums/topic/changing-scalar-range/#:~:text=Ansys%20Employee-,If%20you%20uncheck%20Max%2C%20Min%20on%20Color%20Bar%2C%20you%20can,cannot%20increase%20the%20minimum%20value.
Sampat
