September 29, 2023 at 7:12 am
Mayur.Lokhande
SubscriberHeat exchanger geometry: It contains multiple flow path at various temperature ( -20, 20, 50, 80 & 100)
Query: While defining material properties in Ansys, do we need to give temperature dependent young modulus, SS-cure for plasticity, thermal coeff. of expansion, thermal conductivity etc? or single room temperature data of material is sufficient?If single data is enough, how ansys will carry out the calculations at various temperatures?
September 29, 2023 at 12:40 pm
Surya Prakash
Ansys EmployeeHi Mayur,
Please check this KM which discusses about the same.Â
/knowledge/forums/topic/how-ansys-gets-temperature-dependent-material-properties-that-are-define-in-engineering-data-for-example-youngs-modulus-specified-at-23-c-and-100-c-based-on-experimental-data-and-static-analysis-i/
Thanks,
Surya
- The topic ‘Ansys Temperature dependent Properties’ is closed to new replies.
5779
1305
