Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DPM particle data mapping › Reply To: DPM particle data mapping
September 28, 2023 at 4:08 pm
Mohammad
Thank you for your response. The contour plots only displays the particle variables (e.g volume fraction of particles to air) for the particles in the Lagrangian frame i.e you can only see the particles which are coloured by what DPM variable you select in the field function. However, I want to map these DPM variables (e.g volume fraction) onto the volume mesh (Eulerian frame).Â
Kind regards,Â
Mohammad
