Heat simulation
    • Josias Eilers
      If I have added a new liquid and specified the properties: density, Cp, thermal conductivity and viscusity,
      are these sufficient to carry out a heat simulation in ansys fluent,
      in which everything necessary is taken into account to achieve a correct result?
      Even if the aggregate states change during the simulation?
      If it changes state you'll need the vapour properties & enthalpy (latent heat) and the phase change models. Assuming all of the boundary conditions etc are also set.
      I advise going through the thermal course on Learning and looking at the various tutorials in Fluent's Help system.
  • The topic ‘Heat simulation’ is closed to new replies.
