Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Rock drilling › Reply To: Rock drilling
September 27, 2023 at 12:43 am
Reno Genest
You need to tackle these problems one by one and troubleshoot. Ideally, you can reproduce the problem on a small and efficient model to run quickly and troubleshoot faster. You could try to use a coarser mesh and/or scale the size of the model to increase the timestep and run faster.
- Try to fix the contact problem.
- Try different contact types (*CONTACT_NODES_TO_SURFACE; *CONTACT_AUTOMATIC_NODES_TO_SURFACE, etc.). Use the node set of the SPG particles as the SURFA and the segment set of the drill surfaces as SURFB.
- Change the SOFT option. Try SOFT=1 (best for SPG).
- Increase the contact stiffness. Set SOFSCL=0.9
- Decrease the bucket sort frequency to 1. Set BSORT=1
- Refer to the presentation on contacts I sent you earlier.
- This may require many trials and errors.
- SPG is a particle method; there is no negative volume. Set ERODE=0 on *CONTROL_TIMESTEP to get rid of those messages.
- I don't know. Try to create a new post for this question.
- You need a TIED contact between the SPG particles and the ring.
Reno.
