Ansys Products
Ansys Products
Fluent doesnt start at all
    • karthik.ramanadhan
      My Fluent is not responding (simply put). Everytime i try to open it separately or through the ansys workbench, it doesnt load at all. I have tried to reinstall ansys 3 times already, after wiping all the folders . Everything else works fine, except for Fluent.
      I am currently resorting to CFX which works quite well.
      My Asus laptop has a 16GB ram with an i7 processor, and a GTX950M graphics card updated with the latest drivers. I dont know what other fixes to try out. Please help me out.
      The screenshot was taken after almost an hour of waiting after which i get the messge "Fluent Application Failed to start"
      Thanks in advance.
    • tsiriaks
      Hi karthik.ramanadhan,
      It usually doesn't hang on this launcher page.
      What if you bypass it.
      Open CMD Prompt then issue the following command (change your version and installation path accordingly)
      "C:Program FilesANSYS IncANSYS Studentv191fluentntbinwin64fluent.exe" ^-r19.1.0 3d -meshing
      Does this work ?
      If not, try non-gui mode
      "C:Program FilesANSYS IncANSYS Studentv191fluentntbinwin64fluent.exe" ^-r19.1.0 3d -g -meshing
      It may also be worth trying to turn off any Anti-virus software and Firewall on the machine.
      Thank you,
      Win
      Thanks for the reply.
      I tried using the cmd promt for running fluent and it worked.
      So why isnt it working through the launcher? What settings can i use in the launcher or apart from that, to run fluent through the Ansys workbench?
      Firewall and Antivirus were off for all the trials.
    • DrAmine
      Are there any errors in the installation log file?
      I reinstalled again. Found no errors. Still only works via the command prompt option. Is there a way to bypass the launcher if we go through workbench?
    • Keyur Kanade
      Moving to installation category.
      Keyur
    • tsiriaks
      Hi karthik.ramanadhan ,
      Please post the screenshots of the following:
      - Open CMD Prompt, then type 'set' (without quote)
      - Open CMD Prompt, then type 'dxdiag'(without quote) , post screenshots of the first page and the tab that says 'Display'
      - Open Windows File Explorer and browse to the drive where ANSYS is installed on (e.g., if it's installed under C:Program FilesANSYS IncANSYS Student , just browse to C:) , then make sure you can see all hidden files, and take the screenshot of the content of this drive.
      Thank you,
      Win
       Hi
      Sorry for the late reply. Appreciate the assists so far.
      -CMD 'set' text file here
      -Dxdiag screens
       First page
      Display tab
      -Installation Folders Screens
      -----C drive with "Show hidden"
      Cdrive will no hidden
      ----Ansys Student folder
      As per what you had suggested earlier, Ansys still works only with cmd prompt for me. The launcher constantly hangs.
    • tsiriaks
      The link to download the text file for 'set' output is blocked from our network. Could you post the content here ?
      For the screenshot of the C drive, can you go up one level from C:Program Files to show the content of C:
      Thank you,
      Win
    • tsiriaks
      Thanks for the info.
      Can you try rearranging the value order of your Path environment variable ?
      The current order is something like this
      C:Program Files(x86)Common FilesOracleJavajavapath;C:Program Files (x86)InteliCLS Client;C:Program FilesInteliCLS Client;C:Windowssystem32;C:Windows;C:Windowssystem32Wbem;C:Windowssystem32WindowsPowerShellv1.0;..........
      I would like to try moving those that start with C:Windows to be at the front, so it would be something like this
      C:Windowssystem32;C:Windows;C:Windowssystem32Wbem;C:Windowssystem32WindowsPowerShellv1.0;C:Program Files(x86)Common FilesOracleJavajavapath;C:Program Files (x86)InteliCLS Client;C:Program FilesInteliCLS Client;..........
      But before making change to the value of the environment variable, please make sure you backup the current value into some text editor application like notepad, words, etc.
      Thank you,
      Win
      Thanks you so much. This worked.
      If i could reach into the screen and shake your hand i would !
    • tsiriaks
      That's excellent news !! I'm glad it works properly for you now !
      Haha, I would too
      Thank you,
      Win
    • lzwang26
      Hi tsiriaks:
      I have the similar problem. An accidental power outrage happened when fluent is running, then I can never open it. I have rearrange the system environment variables order as you said, but it still doesn't work. Could you please help me about this?
      Thanks so much!
    • tsiriaks
      There are actually other things to try/check as well when you encounter issue like this.
      Is this happening with stand-alone Fluent or Workbench-Fluent ?
      If your stand-alone Fluent is fine, try the following command in CMD Prompt. Make sure all ANSYS applications are closed first.
      move "%appdata%ansys" "%appdata%ansys.old"
      If your stand-alone Fluent doesn't work either, let us know the issue. Maybe, screenshot of the error message if exist.
      Thanks,
      Win
    • Hamid1365
      Hi tsiriaks,
      I have got the same issue and tried all the ways you suggested. Not stand-alone Fluent nor through workbench works. please help me fix this problem
      Thanks
      Hamid
    • cfdasdf
      Applying the "move ..." command actually didn't work for me. I have the issue that Fluent standalone works but it doesn't open in the Workbench environment.
      Are there any other suggestions to solve this?
      When Fluent fails, does the interface launch? If so, please scroll up to the top of the TUI and post what it says.
Viewing 18 reply threads
  • The topic ‘Fluent doesnt start at all’ is closed to new replies.
