Ansys Learning Forum Forums Discuss Simulation General Mechanical Bad gap space for interaction.. Run check Reply To: Bad gap space for interaction.. Run check
Missy Ji
For the error message:”Bad gap space for interactions- Run Check.” When you are using the contact type “External Gap”. you need to have the parts initially separated by the Gap Size. In your model, the minimum clearance between the surfaces of one or more subgrids is less than the specified gap size. If you run a check on your interaction setup, you will find that you don’t have gaps between Lagrange parts, they are penetrating into each other.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_adyn/adyn_inter_laglag_intro.html
