Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Solid Body Motion (Fluent Conjugate Heat Transfer Modeling) › Reply To: Solid Body Motion (Fluent Conjugate Heat Transfer Modeling)
September 25, 2023 at 12:23 pm
Federico
You should consider using a Dynamic Mesh 12.6. Using Dynamic Meshes (ansys.com).
Here's an example: ANSYS Fluent: Dynamic Mesh Problem for a Piston and Reed Valve - Part I - YouTube (you may not need the 6DOF model)
You can prescribe the solid/fluid1 motions using a profile.
