The plate is fixed with a fixed support from bottom
The velocity is assigned only to the cylinderical bar
The velocity magintude is 100 m/s
The direction is towards the fixed plate
I remove the contacts completely and I considered the interaction to be fricionless, below are some screenshots:
Please Login to Report Topic
Please Login to Share Feed
Edit Discussion
You are navigating away from the AIS Discovery experience
