Humidity over 100%
    • buksa
      Yes, that's possible. If you've not included any condensation models (multiphase or wall film) the RH calculator will just return the value based on the cell conditions.
      The next step is to decide if you just need to report that there is likely to be condensation, or whether you need to spend the computation time working out how much condensation you might get.
    • buksa
      Ok, thank you!
  • The topic ‘Humidity over 100%’ is closed to new replies.
