enthalpy at melting single bead parametric simulation in ansys additive
    • n n
      where can i found the value of the enthalpy at melting (J/m3 ) in ansys additive ?
    • Zoi Stavrothanasi
      If you want to define the enthaly of a material you have to access the Engineering data, then sletect Thermal from the Toolbox and finally drag Enthaly and drop it in the property section. Hope this helps!
      Zoi
    • Zoi Stavrothanasi
  • The topic ‘enthalpy at melting single bead parametric simulation in ansys additive’ is closed to new replies.
