Copy tree components
    • jonsys
      Hello Community,
      How can someone copy some Project tree components (say Construction Geometry, Mesh, Boundary conditions or even Solution Output) from Mechanical of a .wbpj file to another one?
    • Ashish Khemka
      You can export the model ( .mechdat file) from one Mechanical and then import the same and assemble it into other Mechanical. This only looks the way to me.
      Ashish Khemka
    • jonsys
      Hello Ashish
      thank you for your answer.
      What if I want Construction Geometry from proj1, Mesh from proj2, Boundary conditions from proj3 and want to gather them in proj4?
    • Ashish Khemka
      You can copy the global coordinate based construction geometry but similar thing for mesh and boundary condition is not possible.
      Ashish Khemka
    • jonsys
      alright, thank you for the answer Ashish,
    • Ashish Khemka
      No problem
Viewing 5 reply threads
  • The topic ‘Copy tree components’ is closed to new replies.
