October 4, 2018 at 7:50 pm
October 4, 2018 at 9:17 pm
peteroznewman
Subscriber Hello Sam,
If you pick a face, you will pull a solid, if you pick curves or edges, you will pull a surface.
Please figure out how to set your screen capture utility so you don't end up with a huge whitespace at the bottom of your image.
Peter
October 4, 2018 at 9:40 pm
Sam Fares
SubscriberHi Peter,
I can't replicate what i did earlier. if i draw a rectangle it will always turn into a surface so when i pull on it it turns into solid. i am not sure how i was able to generate that box ( only sides pulled out) that you saw earlier in my screen capture.
Sam
October 4, 2018 at 10:34 pm
Sandeep Medikonda
Ansys EmployeeSam,
 Once a solid is created, you do 2 things 2 create a box. You can select a face and hit Ctrl+X and Ctrl+V. This will create a box of surfaces. Alternatively, you can use the Shell tool and specify a thickness to create a box of a certain thickness. Note that this will still be a solid body.
Sandeep
Best Practices to post on the Student Community -
October 5, 2018 at 11:19 am
October 5, 2018 at 1:32 pm
Sam Fares
SubscriberYes i did check"create layout curves" but i didnt know what it does. You answered my question.Â
Thank you all!
Sam
October 5, 2018 at 4:11 pm
FrankD
Ansys EmployeeRegular curves in sketches will Auto-close if possible, even if nested or multiple-region-ed, in order to make the simplest set of surfaces. Selecting curves manually for Pull can make that open box that you showed, or else selecting just edges of flat surfaces and pulling them, only. This is usually useful for modeling, and can even (to a limited extent and until these auto-created faces are further complicated) revert to the original curves when returning to the sketch for further edits.
The Create Layout Curves option tells these curves not to be considered 'transient' and keeps them out of the automatic closing behavior when exiting the sketch, while also associating them to the plane in which they are defined.Â
- The topic ‘Pull’ is closed to new replies.
6625
1311
