Automatic changes to named selections during mesh assembly in workbench
    • thierry.bourdon
      I'm working on a simulation project in ANSYS Workbench, and I'm facing a problem where named selections are automatically changed when performing mesh assembly (It add automatically *External model and *D3 which is the name of the model).
      How can I disable the automatic addition of model names to named selections in ANSYS Workbench when performing mesh assembly
    • Lydia Lymperopoulou
      Hi Thierry,
      could you check if Topology Checking is selected to yes? You can find this feature in the Options panel
      • thierry.bourdon
        Hello Lydia, I have the same thing as you, and it's still affecting the named selections.
    • Govindan Nagappan
      Hi Thierry,
      In properties of "Model" cell, turn off object renaming
      See if it helps
  • The topic ‘Automatic changes to named selections during mesh assembly in workbench’ is closed to new replies.
