October 4, 2018 at 3:44 am
zjuv9021
SubscriberHi All,
I am working on a project that involves a multilayered hyperelastic tubing that I would ultimately like to be able to place displacement compressions, twist it, bend it, etc. involving nonlinear frictional contact. I am currently treating these as Isotropic, but do have uniaxial, biaxial, and shear test data available for some Mooney-Rivlin parameter fittings... but figured I'd figure out Isotropic FIRST.
Geometry/Materials:
- Inner tube: Silicone Rubber; Young's Modulus: 250 psi (0.49 Poisson's Ratio)
- Second layer: Polyethylene terephthalate (PET) monofilament (treated as a 3D surface wrapped around in contact with the silicone); Young's Modulus: 71,000 psi (0.49 Poisson's Ratio)
- Third Layer: Polyurethane 80A; Young's Modulus: 500 psi (0.49 Poisson's Ratio)
- Fourth outer-most layer: Polyurethane 55D; Young's Modulus: 2,500 psi (0.49 Poisson's Ratio)
The tubing below is 0.500" long.
Contact:
- Silicone Rubber->PET: Frictional Contact with a coefficient of 0.1
- PET->PU80A: Frictional Contact with a coefficient of 0.1
- PU80A->PU55D: Bonded Contact
Mesh:
- I am currently utilizing hex dominant method. I'm not sure if Contact Match or Node Merge could come in handy here. Open for opinions regarding this kind of surface contact.
BCs:
- One end is fixed, and the other end faces have constraints in the x-z plane with a displacement of 0.1" in the negative y direction to compress towards the fixed end in hopes to induce a buckling shape.
- There is also a pressure (fluid moving through the tubing) of 1 psi inside the silicone tubing.
Issues:
- As with most people, convergence. "Contact Status has Experienced an abrupt change". Highly distorted elements.
- I've even run my Eigenvalue Buckling to get my critical load factor that would induce my first buckling shape:
I took the Load Multiplier and multiplied that by my load applied to this tubing (1 lbf) to determine the critical buckling load, and then added ~20% increase to this value along with a perturbation in Nonlinear Structural to try to obtain some post-buckling behavior but had no success with this.
I'm a little lost with this, let alone how to even start including non-linear material modeling, so any help or thoughts is GREATLY appreciated!
Zach
zjuv9021
SubscriberPS: Please see the attached .wbpz for the actual project.
Zach
October 4, 2018 at 5:35 pm
Sandeep Medikonda
Ansys EmployeeZach,
I am unable to look at the file, but can you post a couple more snapshots of the Analysis settings and the Frictional Contact you have?
Also, what material models are you using? Are you fitting these in Engineering Data?
Sandeep
Best Practices to post on the Student Community -
October 4, 2018 at 6:25 pm
October 4, 2018 at 11:02 pm
Sandeep Medikonda
Ansys EmployeeHi Zach,
Please see if the following suggestions help:
- Look at the Force Convergence plot and the Newton-Raphson residuals.
- There are numerous posts in the forum on these 2 if you are not sure how to read them or request them.
- Dropping mid-sized nodes helps? Just change the Mesh from quadratic to linear under Mesh.
- See if further reducing the Normal Stiffness or aggressive update of contact stiffness help?
- Double check your pinball radius and increase it if needed?
- Use the Initial Contact tool to check this. Again there are posts in the forum on this.
- See if using the Unsymmetric solver helps? Can be changed in Analysis>Nonlinear Controls>Newton-Raphson Option
- Introduce some Stabilization Damping Factor in contact, say 1e-02 and see if it helps.
- If nothing helps add some Stabilization Energy to your model from Analysis Settings>Nonlinear Controls> Stabilization. Use: Constant, Energy, .05, No and 0.2 as options for the following cells. Note that you have to be careful with the amount of artificial energy you add. So, check on this while post-processing the results
Sandeep
Best Practices to post on the Student Community - Look at the Force Convergence plot and the Newton-Raphson residuals.
October 5, 2018 at 12:05 am
peteroznewman
SubscriberHi Zach,
I looked at your archive and noted that your mesh could be improved to help the solver converge.
I think putting two elements through the wall thickness is going to help.
If you split the bodies in SpaceClaim, you can get the nodes to line up exactly.
Would it be worthwhile to eliminate the frictional contact and have these different materials effectively bonded together using Shared Topology? That way, the different materials will share nodes at the common face and the likelihood of convergence would be much greater.
Peter -
October 5, 2018 at 12:07 am
zjuv9021
SubscriberThank you Peter,
I am not as familiar with Shared Topology. What do I lose with utilizing this feature? Can I ever implement frictional contact in this scenario?
Kind Regards,
Zach
October 5, 2018 at 4:17 am
zjuv9021
SubscriberSandeep,
Do you know why dropping midside nodes helps in this particular model?
Zach
October 5, 2018 at 8:15 am
peteroznewman
SubscriberZach,
You mentioned you are using isotropic materials, before you make the model more complicated with hyperelastic materials.
In a similar way, you can use no contact, before you make the model more complicated with frictional contact. It's just another way to take baby steps to the full model. It would show you how the multi-layer tube behaves without sliding between the layers. However, if sliding between the layers is the behavior of interest, then there would be no point in taking this approach.
Shared Topology is found in SpaceClaim under the Workbench Tab. You should see the 3 faces and 6 edges shared. Once you have that, you don't need any contact elements. You have hidden solids that complicate sharing, so clean up your geometry before you attempt this.
Peter
October 5, 2018 at 11:19 am
Ashish Khemka
Forum ModeratorHi Zach,
On your query to Sandeep - midside nodes dropped (linear elements) will offer lower stiffness and help in avoiding distortion issue. Looking at the shape, do you expect a self contact? I agree with Peter on taking baby steps - you may use bonded contact between the tubes (just a suggestion - sharing the topology is a way of doing the same without contact) to see how the behavior is and then switch to frictionless or frictional.
Ashish Khemka
October 5, 2018 at 1:50 pm
zjuv9021
I'm interested in trying this route. Is it equivalent to bonded contact, minus having contact elements?
what recommends do you have for 'cleaning up' my geometry? For now i'll start to play around with this feature.
Zach
October 5, 2018 at 3:28 pm
peteroznewman
SubscriberZach,
Shared Topology allows different materials to be bonded together without Bonded Contact. One benefit is slightly smaller models that will solve in less time.
In SpaceClaim, you have 8 solids with 4 hidden.
In Mechanical, you suppressed 4 solids.
I assumed the four suppressed solids matched the four hidden solids, but I was wrong.
The better practice is to select four solids in SpaceClaim and Suppress for Physics. That is what I have done for the last four solids and I flipped the visible set. You can see at the bottom of the image below the Share Topology setting is set to Share. Sometimes that is all you need to do.
When I try the Share tool in Workbench, I don't get all three faces, I have to change the Coincidence Tolerance in the Options to be 0.0001 mm otherwise it tries to jump across a wall thickness and collapse one of the walls to nothing. When I try to Share, it finds 3 faces and 7 edges. It should find 6 edges. This extra edge being shared may be a source of difficulty in meshing. If I increase the Tolerance, it goes down to 2 faces before it drops to 6 edges.
Did you import this geometry or create it in SpaceClaim? If you imported, try creating it from scratch in SC.
Peter
- The topic ‘Hyperelastic multi-layered tube buckling/compression’ is closed to new replies.
6485
