ANKLE RIGID DYNAMICS // Wie Winkel in Mehrkörpersimulation als Eingabeparameter?
    • Svenja Steinbach
      Hallo,
      ich möchte in meiner MKS als Eingabeparameter keine Geschwindigkeit oder Beschleunigung als Eingabeparameter verwenden, sondern einen bestimmten (Rotations-)Winkel. Ist das möglich? Wenn ja, wie?
      Vielen Dank für eure Hilfe im Vorraus!
      I don't want to use speed or acceleration as an input parameter in my MKS, but rather a specific (rotation) angle. Is this possible? If yes how?
      Thank you for your help in advance!
    • Lydia Lymperopoulou
      Hello Svenja,
      Boundary conditions are very important when you perform an FEA analysis. This link provides information for all the available BC in Ansys Mechanical https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_sim/ds_boundary_condition_types.html which may come useful while simulating a problem.
      More specifically, because I understand you want to enforce a specific rotational angle I would reccomend using Remote Displacement BC https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_sim/ds_Remote_Displacement.html?q=remote%20displacement . If this doesn't work for you, check the list of BC on the first link to see which one simulates best your problem.
    • Svenja Steinbach
      Unfortunately the articles are not accessible to me.
    • Erik Kostson
      Hi Svenja
      See the below article/post on how to access these links in an easy way:
      All the best
      Erik
  • The topic ‘ANKLE RIGID DYNAMICS // Wie Winkel in Mehrkörpersimulation als Eingabeparameter?’ is closed to new replies.
