September 16, 2023 at 5:57 pm
September 18, 2023 at 10:41 am
Timos
Ansys EmployeeHello, there is no need to calculate the force on the whole tooth. The force is calculated by intergrating surface force on all surfaces of the object surrounded by air. In both cases a small difference is expected because of the intergration points being quite different (mesh).
September 18, 2023 at 12:45 pm
841563439
SubscriberOkay, Timos,thanks! That is to say, the position of the 4 cutting teeth as shown in the figure is all OK, but because of the factors such as division, the calculated force will be somewhat different, right?
September 21, 2023 at 4:02 pm
841563439
SubscriberOkay, Timos,thank you very much! That is to say, the position of the 4 cutting teeth as shown in the figure is all OK, but because of the factors such as division, the calculated force will be somewhat different, right?
- The topic ‘Radial force of the motor teeth’ is closed to new replies.
