About electrostatic field analysis in MAPDL
    • ty_jpn
      Dear everyone,
      Maxwell cannot be used due to licensing issues.
      I created the program below to simulate the effect of fringe electric fields on parallel plate capacitors in MAPDL, but the simulation does not work well.
      /CLEAR
      /PREP7
      ! プレートの寸法(μm単位をmm単位に変換)
      width = 0.1
      height = 0.02
      thickness = 0.003
      separation = 0.01
      ! 3D 8ノード要素の静電解析用に設定
      ET,1,SOLID122
      ! 無限要素を定義
      ET,2,111,2,1
      ! 材料特性(真空の相対誘電率)
      MP,PERX,1,8.854e-12
      ! 最初のプレートを作成
      BLOCK,0,width,0,height,0,thickness
      ! 二番目のプレートを作成
      BLOCK,0,width,0,height,separation,separation+thickness
      ! メッシュ設定
      ESIZE,0.005   ! 要素サイズを設定
      ! すべてのボリュームにメッシュを適用
      ALLSEL,ALL
      VMESH,ALL
      /SOLU
      ! 静電解析を指定
      ANTYPE,STAT
      ! 境界条件
      ALLSEL
      CSYS,0
      ! 最初のプレートの上面に0Vを適用
      ASEL,S,LOC,Z,thickness
      NSLA,S,1
      D,ALL,VOLT,0
      ! 二番目のプレートの下面に1Vを適用
      ALLSEL
      ASEL,S,LOC,Z,separation
      NSLA,S,1
      D,ALL,VOLT,1
      ! 解を求める
      SOLVE
      FINISH
      /POST1
      PLNSOL,VOLT  ! ノード解(電圧)をプロット
      ! 電場エネルギーを抽出して容量を計算
      /OUT, CAPACITANCE_CALCULATION, , TXT
      *GET, W, ENER, , STAT, ENE
      V = 1
      C = 2*W/(V**2)
      *STATUS, C
      /OUT
      Please tell me what needs to be improved.
      thank you
    • Ashish Khemka
      Translated:
      Dear everyone,
      /CLEAR
      /PREP7
      ! Plate dimensions (convert from μm to mm)
      width = 0.1
      height = 0.02
      thickness = 0.003
      separation = 0.01
      ! Configured for electrostatic analysis of 3D 8-node elements
      ET,1,SOLID122
      ! Define infinite element
      ET,2,111,2,1
      ! Material properties (relative dielectric constant in vacuum)
      MP,PERX,1,8.854e-12
      ! Create your first plate
      !Create second plate
      ! Mesh settings
      ESIZE,0.005 ! Set element size
      !Apply mesh to all volumes
      ALLSEL,ALL
      VMESH,ALL
      /SOLU
      ! Specify electrostatic analysis
      ANTYPE,STAT
      ! boundary condition
      ALLSEL
      CSYS,0
      !Apply 0V to the top of the first plate
      NSLA,S,1
      D,ALL,VOLT,0
      !Apply 1V to the bottom of the second plate
      ALLSEL
      NSLA,S,1
      D,ALL,VOLT,1
      ! Find the solution
      SOLVE
      FINISH
      /POST1
      PLNSOL,VOLT ! Plot node solution (voltage)
      ! Calculate capacity by extracting electric field energy
      V = 1
      C = 2*W/(V**2)
      *STATUS, C
      /OUT
      thank you
    • wrbulat
      Please try the listing below. In electrostatic analyses, one models/meshes the domain enclosing the electrodes (not the electrodes themselves). The electrodes are usually represented by voids in a mesh of the domain that encloses them. I didn't bother to add the INFIN111 elements (it's a little tedious - pardon me for getting cheap on you). You can increase the value of parameter d_dmn in successive runs until the value of the calculated capacitance stops changing significantly.
      If memory serves, INFIN111 will not account for additional electrostatic energy of the infinite domain that extends beyond the boundaries of the SOLID122/123 mesh. So if you do use them, my second approach for assessing the capacitance would be, I believe, the more accurate way (divide the charge reaction on one of the electrodes by the applied voltage difference).
      Cheers,
      Bill
      fini
      /cle
      /vie,1,1,1,1
      /sys,del file*.png
      /PREP7
      C*** Plate dimensions (we'll assume this is in meters)
      eps0=8.854e-12 ! FREE SPACE PERMITTIVITY
      width = 0.1
      height = 0.02
      thickness = 0.003
      separation = 0.002 !0.010
      d_dmn = 0.010 ! DEPTH SURROUNDING DOMAIN EXTENDS BEYOND ELECTRODES
      d_inf = 0.005 ! DEPTH OF INFINITE BOUNDARY ELEMENT MESH
      esz = 0.003 ! MESH SIZE
      V = 1 ! APPLIED VOLTAGE
      C*** Configured for electrostatic analysis of 3D 8-node elements
      ET,1,SOLID123
      C*** Define infinite element
      ET,2,111,2,1
      C*** Material properties (relative dielectric constant in vacuum)
      !MP,PERX,1,8.854e-12 ! THIS IS ABSOLUTE PERMITTIVITY IN MKS, WHICH WORKS OK, BUT...
      MP,PERX,1,1 ! WE GENERALLY USE RELATIVE PERMITTIVITY INSTEAD
      C*** Create your first plate
      BLOCK,0,width,0,height,0,-thickness
      cm,electrode1_a,area
      C*** Create second plate
      asel,none
      cm,electrode2_a,area
      C*** SURROUNDING DOMAIN
      alls
      cm,scrap1_v,volu
      *get,xmin,kp,,mnloc,x
      *get,xmax,kp,,mxloc,x
      *get,ymin,kp,,mnloc,y
      *get,ymax,kp,,mxloc,y
      *get,zmin,kp,,mnloc,z
      *get,zmax,kp,,mxloc,z
      vsel,none
      bloc,xmin-d_dmn,xmax+d_dmn,ymin-d_dmn,ymax+d_dmn,zmin-d_dmn,zmax+d_dmn
      cm,scrap2_v,volu
      alls
      vsbv,scrap2_v,scrap1_v
      C*** MESH
      esiz,esz
      vmes,all
      C*** ELECTRODE VOLTAGE
      da,electrode1_a,volt
      da,electrode2_a,volt,V
      fini
      C*** SOLVE
      /solu
      alls
      save
      solv
      fini
      C*** POST PROCESS
      /post1
      set ! READ RESULTS INTO MADL DATABASE
      etab,w,sene ! BASED ON ENERGY
      ssum
      *get,Wnet,ssum,,item,w
      C1 = 2*Wnet/(V**2)
      nsel,s,d,volt ! BASED ON CHARGE & VOLTAGE
      fsum
      *get,q,fsum,,item,chrg
      c2 = q/v
      C_nominal=eps0*(height*width)/separation ! NOMINAL FRINGE FREE VALUE
      /tla,-0.35,0.90,Capacitance (ANSYS, energy) = %C1% Fd ! ANNOTATION
      /tla,-0.35,0.85,Capacitance (ANSYS, Q/V) = %C2% Fd
      /tla,-0.35,0.80,Capacitance (nominal fringe-free) = %C_nominal% Fd
      alls ! CAPPED SECTION PLOTS
      wpro,,,90
      wpof,,,width/2
      /type,1,7
      /cpl,1
      plns,volt
      /sho,png $plns,volt $/sho,close $/wait,2
      plve,ef,,,,vect,,on
      /sho,png $plve,ef,,,,vect,,on $/sho,close $/wait,2
      /eof
      • ty_jpn
        dear Bill
        Thank you for your answer.
        I tried it right away and was able to successfully analyze it. It never occurred to me to mesh the area instead of the electrode.
        I have an additional question: What kind of command operation should I use to extract the electric field leaking from the electrode?
        Where is the capacitance worth when there is a fringe?
        Thanks
    • ty_jpn
      misstake post
    • ty_jpn
      postscript
Viewing 4 reply threads
  • The topic ‘About electrostatic field analysis in MAPDL’ is closed to new replies.
