September 13, 2023 at 10:09 amPeter SchackSubscriberWhat is the right way to generate a rotating wall in 2023 R2. In 2023 R1 I define an rotating wall and the software handle both, the Conducting Non-Slip Wall (default) AND the manualy defined Rotating Wall in a right way. (Massage that the Overlapping will be ignored) If I load my Model in 2023 R2 a massage that this "Overlapping" is not permissible. It is not possible to start the solve.
September 13, 2023 at 10:32 amDevendra BadgujarForum Moderator
Hello Peter,Â
Can you please share the image of the message to understand this better? Also, does this overlapping conditon conflicts with any connections or interfaces?Â
DevendraÂ
September 13, 2023 at 11:28 am
September 13, 2023 at 11:33 am
September 13, 2023 at 11:42 amDevendra BadgujarForum Moderator
Hello Peter,Â
Thanks for sharing the image. Let me qucikly check this with the team and get back to you.Â
DevendraÂ
September 13, 2023 at 12:04 pmPeter SchackSubscriber
Thanks for the quick turnaround ?
Peter
September 28, 2023 at 6:01 amDevendra BadgujarForum Moderator
Hello Peter,Â
Discussing through Service request, closing this to avoid duplication.Â
DevendraÂ
Viewing 6 reply threads
- The topic ‘rotating wall in a CHT simulation 2023 R2’ is closed to new replies.
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
513
488
225
209
