September 12, 2023 at 3:32 pm
Xin Yan
SubscriberHi,Â
I recently updated Ansys to 2023 R2. And it took me some time to locate Mechanical APDL in Workbench. Normally it is on the starting list.
I tried to create a 3D model and export as cdb file. The issue is that the cdb model can not be read in either Hypermesh or Actran.
In Hypermesh, it shows Resolution: The element is not processed
In Actran, the model only includes isolated nodes.
Is there any way to fix that?
Thanks!
Xin
September 13, 2023 at 1:26 pm
Ashish Khemka
Forum ModeratorHi,
If you export the .cdb file in earlier versions - does it work fine? Also, ou can try comparing different .cdb file using notepad app.
Ashish Kumar
September 13, 2023 at 2:02 pm
September 13, 2023 at 2:57 pm
Mike Rife
Ansys EmployeeHi Xin Yan
The MAPDL cdb format was updated at version 2023R1. Please reach out to Hypermesh and Actran technical support to find out when they will be implementing the necessary changes. Mike
September 13, 2023 at 3:21 pm
Xin Yan
Subscriber-
September 13, 2023 at 3:29 pm
Mike Rife
Ansys EmployeeSearch for where the element types are defined and compare.
- The topic ‘Ansys Mechanical APDL failed to export cdb mesh.’ is closed to new replies.
5649
1885
1403
1303
