3D Design
3D Design
Sheet Metal BUG
    • Roberto
      Hello , I send you a video where an error occurs when the sheet metal is unfolded?
      If you unfold the sheet metal by selecting the INSIDE face and place it on the drawing board the geometry is mirrored with the wrong bend degrees.
      The geometry should be positioned the same way as when unfolded before inserting it into the table.
      This causes errors in the production of the pieces and they have to be thrown away. Will this bug be fixed?
      Regards
    • Devendra Badgujar
      Hello Roberto,
      Let me check and get back to you on this.
      Devendra
    • Roberto
    • Roberto
      Hello Devendra
      I hope I have attached everything for you
      Regards
    • Devendra Badgujar
      Hello Roberto,
      I have removed the video and files from the post. I have recieved the files you shared and will look into those.
      I will get back you with more information soon. Thank you for your understanding!
      Devendra
    • Roberto
      Hello, do you have any information regarding this problem?
      Regards
    • Roberto
      Hello Devendra
      It's been a month now, do you have any news regarding this problem?
      Regards
    • Devendra Badgujar
      Hello Roberto,
      Apologies for the delay, I have not heard back from the team on this, will check and get back to you.
      Devendra
    • Roberto
      Hello Devendra
      Thank you, I'm waiting for your info, this error is important because the unfolded are incorrect
      Regards
    • Roberto
      Hello Devendra
      Do you have any news regarding this problem?
      Regards
Viewing 9 reply threads
  • The topic ‘Sheet Metal BUG’ is closed to new replies.
