September 12, 2023 at 8:23 am
Marco Airoldi
SubscriberÂ
I'm attending the getting started class of Maxwell. The first exercise, when i draw a polygon curve and try to sweep it around the x axis, maxwell outputs an error even though i've input exactly the same values and followed the exact same steps.Â
The error is
PARASOLID ERROR: sweep failed function PK_BODY_make_swept_2type PK_BODY_sweep_tool_self_int_c.Â
Body could not be created because of invalid parameters to sweepAroundAxis operation.
Could you help me out please ?
September 13, 2023 at 9:12 pm
GLUO
Ansys EmployeeHi Marco,
The training document example was using 2022R2 and before versions. There is a geometry kernel update update after 2022R2 version. Could you let me know which version of AEDT you are using?
GL
- The topic ‘Problem while sweep around axis’ is closed to new replies.
Ansys Innovation Space
1243
1092
1068
953
