September 25, 2018 at 3:25 am
September 25, 2018 at 4:52 am
Keyur Kanade
Ansys EmployeeYou can do it using SpaceClaim.Â
http://www.spaceclaim.com/en/Support/Tutorials/Essentials/SpaceClaim_Basics_Tutorials.aspx
If you have case file, please export is as .msh file. Then you can open this .msh file in SpaceClaim. You can refer this .msh file in SpaceClaim to create a new sketch.Â
Keyur
September 25, 2018 at 4:53 am
Keyur Kanade
Ansys EmployeeYou can do it in SpaceClaim
You can create a sketch in SpaceClaim then use Pull command to convert it to 3D.Â
Keyur
September 25, 2018 at 5:34 am
rumth
SubscriberHi Keyur,
Thank you for your reply. SpaceClaim seems tough to me. It would be good if I can do it using DesignModeler.
Raju.
September 25, 2018 at 6:17 am
Keyur Kanade
Ansys EmployeeHi,Â
You can use DesignModeler. You will need to create a sketch and use dimensions for the same. Please refer to following video for basics.Â
https://www.youtube.com/watch?v=ik7Ns-4zbRI
It is just 2D sketch. Once you have a sketch, then you can use Extrude or Revolve commands to convert that sketch to 3D.Â
Keyur
September 25, 2018 at 6:18 am
Keyur Kanade
Ansys EmployeeHere is one more link.Â
https://www.youtube.com/watch?v=tOccFv6Al8I
Hope it helps.
Keyur
- The topic ‘Need help to draw this 2D geometry in 3D.’ is closed to new replies.
6600
1311
