Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Using theta J (RthJA) in a icepak simulation › Reply To: Using theta J (RthJA) in a icepak simulation
September 7, 2023 at 4:06 pm
Eric Steimle
okay. I see you make a hollow object by deselecting the "solve internal" option for your object. So I tried that, assigned a 2R model to the top and bottom face of a pad and the simulation ran! Hurray, but when I try to generate temperature plots or generate a plot of the network temperature I get no output. compared to if I just assigned a thermal source here I'd see the temperatures.
