Ansys Learning Forum Forums Discuss Simulation Electronics Using theta J (RthJA) in a icepak simulation Reply To: Using theta J (RthJA) in a icepak simulation
Rabindra Paul
Eric,
Thanks for the note. As the error message says, the network face should have mesh on one side of the face. Typically, the network face must be on a hollow block or at the domain boundary. You might use resistance plate or individual side option or use 2 R network on a hollowblock (by allowing negligible heat in other direction by adjusting the resistance values). Hope this helps.
Rabindra
