Ansys Products
Ansys Products
Could not connect to license server!
    • handoyo
    • handoyo
      can any one help me ?
    • Divya-Shree Surendran
      Can you check this path C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64 (default install path) and check if you have any update folder? If so, can you move the contents of the update folder to the winx64 folder?
      Thank you.
    • alonsoamz
      I have the same problem
    • tsiriaks
      Hi handoyo and alonsoamz,
      Please check your username and computer name and make sure that there is no special characters. I would recommend to just try creating a user profile with simple english letter like 'abc' or something and see if you get the same issue.
      You can also refer to this thread
      /forum/forums/topic/licensing-issue-after-starting-spaceclaim/?order=all#comment-565b81f3-565b-494b-a041-a93f0159292d
      Thank you,
      Win
    • Sushant
      I have also same problem
    • tsiriaks
      Let us know what you have tried so far
Viewing 6 reply threads
  • The topic ‘Could not connect to license server!’ is closed to new replies.
