September 14, 2018 at 8:04 pm
Erik Chisholm
SubscriberHi there,
I am currently trying to run the 19.1 version, the installation appeared successful with no message errors, everything done with admin. rights.
However, when I open the Workbench, the following message appears :
"System.IO.FileNotFoundException: Could not load file or assembly 'Ans.Addins.Infrastructure, Version=19.1.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
  at ACP.Addin.Load(AddinLoadContext context)
  at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
  at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)"
Nothing is loaded in the toolbox.
What could be the problem, this has me stumped (I have deleted all the file and re-installed the software) ?
Thanks
Erik
September 14, 2018 at 9:29 pm
tsiriaks
Ansys EmployeeHi Erik,
Could you provide the exact name of the package that you used to install ?
Do you install ANSYS commercial products or discovery products as well ?
Please also send us the output of the 'set' command (without quotation ' ') in the CMD Prompt.
Thank you,
Win
September 15, 2018 at 1:42 am
Erik Chisholm
SubscriberHi Win,
Thanks for being so swift, ok, so here goes :
– Package downloaded from website : ANSYSACADEMICSTUDENT_191_WINX64.zip
– No other ANSYS commercial (or non commercial) products on this computer
The message is :>Â
System.IO.FileNotFoundException: Could not load file or assembly ‘Ans.Addins.Infrastructure, Version=19.1.0.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified.
I have tried to do this manually but I have the same results
Thanks again,
 cErik -
September 15, 2018 at 3:31 am
Erik Chisholm
SubscriberHi Win,
Okay I have solved the problem.
The required files were on the computer but ANSYS workbench couldn't find the path to the Addins, hence my problem.
I tried manually but that didn't work either, so, after uninstalling all of the components :
1) I unzipped the downloaded file gain
2) Loaded the complete unzipped file folder intro a directory that I created
3) When the installation prompted the directory, I changed the path to the chosen directory
In hindsight it seems obvious as most installation problems are.
I am now looking forward to using the ANSYS software !
Thanks for offering a student version of your software.
Erik
P.S. : For those interested I am using a 5 year old Windows7 based workstation (i7-2920XM, 16 GB, NVIDIA Quadro 2000M) which is more than adequate for the student version.
September 17, 2018 at 6:31 pm
tsiriaks
Thank you very much for the information and I'm glad that you have found a way to resolve the issue.
Just a little clarification.
When the installation wizard prompt you for a directory, did you specify the directory to ANSYSACADEMICSTUDENT191WINX64 folder or did you specify the directory that you like the products to be installed to.
I'm guessing that you meant you did the latter to resolve the issue, correct ?Â
If so, that's the way that the product is supposed to be installed. The installation wizard would like to know where you want the products to be installed on, not where the installation package resides.
Thank you,
Win
September 24, 2018 at 3:38 am
davy.320
SubscriberI am getting the same problem as you, I tried the following steps, would you be able to explain further about the solution.
Hope you can help.
Thanks
Dennis
September 24, 2018 at 6:34 pm
tsiriaks
Ansys EmployeeHi Dennis,
You meant you are getting this exact error message when launching Workbench ?
  at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)"Â
If so, what is the name of the installation package you are using ?
Did you run the installation wizard as 'run as administrator' ?
Go to your installation directory (default is C:Program FilesANSYS IncANSYS Student) , then right click on folder 'v191' > Properties, and post the screenshot here.
Thank you,
Win
October 17, 2018 at 1:27 pm
david.ryvol
SubscriberHi, I have the same problem... package is ANSYSACADEMICSTUDENT_192_WINX64
I tried everything: reinstall, redownload, your solution, nothing helps
Could you share with me where exactely did you install the software? Was it directly into your folder like C:unzipped folder orÂ
C:unzipped folderANSYS IncANSYS Student ?Thanks, David
Hi Win,
Erik
October 17, 2018 at 4:21 pm
tsiriaks
Ansys EmployeeHi david.ryvol,
Don't install software under your unzipped folder. If possible, just install it to the default directory, C:Program FilesANSYS IncANSYS Student.
Thank you,
Win
October 19, 2018 at 5:26 pm
david.ryvol
SubscriberI did this in the first place and got the same problems as described
July 6, 2019 at 1:22 pm
July 10, 2019 at 7:14 pm
tsiriaks
Ansys EmployeePlease try the suggestions and things to check in here
/forum/forums/topic/problem-with-running-workbench/
and see if that helps you.
Thanks,
Win
July 23, 2019 at 5:59 am
July 23, 2019 at 4:36 pm
tsiriaks
Ansys EmployeeThis is a different issue, please create a new thread and include the entire content of the 'Show Details' in your error message box
Thanks,
Win
October 22, 2019 at 3:49 pm
Geckoo
SubscriberHey, I have a very similar issue.
I got a zipped package from my professor which I unsipped to a temporary folder in "Downloads" containing the two files "ANSYS192_WINX64_DISK1" and "ANSYS192_WINX64_DISK2". I installed it using the default path "C:Program FilesANSYS Inc" without any error.
However, when I want to start ANSYS WorkBench I get the error messageUnexpected error: The following required addins could not be loaded: Ansys.Study.Addin.Addin, Ansys.Study.Addin.Gui.Addin. The software will exit.
Details:
The addin Ansys.ACT.WorkBench.Addin could not be loaded, as the assembly C:Program FilesANSYS Incv192Addins/ACT/bin/Win64/Ansys.ACT.WorkBench.dll does not exist.
I ran the wizard as administrator and my windows is in English language (although my ANSYS is in German, but installing in German settings did not work, either). I tried also to create a folder "ANSYS" in "C:Program Files" and install it there - without success.Do you have any idea how to solve this issue?
Thank you very much and best regards
Ruben -
October 22, 2019 at 7:04 pm
tsiriaks
Ansys EmployeeHi Ruben,
Do you have any .err file under C:Program FilesANSYS Inc ?
Also, can you post the entire error message or its screenshot ?
The error message of the original post could also be caused by security (especially anti-virus) software. However, your error message is slightly different (it's a different add-in) but it's worth try reinstalling again (make sure you completely remove ANSYS Inc folder first) while these security software is off.
Thanks,
Win
October 23, 2019 at 8:17 am
October 24, 2019 at 9:50 pm
tsiriaks
Ansys EmployeeDo you have that Ansys.ACT.WorkBench.dll. in that directory ?
If not and if there is no .err file (error file) , it means ANSYS installer did install it but something on your machine remove it afterwards, which is very likely security software.
I'd recommend to try reinstalling it while temporarily turn off security software, and make sure you run the setup.exe with 'run as administrator'
October 29, 2019 at 9:35 am
October 29, 2019 at 4:48 pm
tsiriaks
Ansys EmployeeThat's great ! Thank you for the update !
November 5, 2021 at 11:14 am
November 5, 2021 at 11:16 am
November 5, 2021 at 12:13 pm
Forum Moderator.Open Workbench and open the archive from there. Do not try and double click from file manager as it nearly always goes wrong with archives.
November 5, 2021 at 12:51 pm
mubeen
Subscriber.I cannot find the workbench in apps but I have downloaded it as mentioned in the installation steps still cannot find it in apps, how to solve this issue??
November 5, 2021 at 12:54 pm
November 8, 2021 at 9:49 am
Forum Moderator.Where did you install it? I can see what looks like the extracted folder.
April 28, 2022 at 4:19 am
stalin_97
Subscriber.When starting tool, showing that security error, what I can do
April 28, 2022 at 4:25 am
stalin_97
Subscriber.
April 28, 2022 at 8:43 am
Forum Moderator.stalin_97 please keep to one thread.
September 22, 2023 at 2:18 am
Piyush Nepal
SubscriberAn unexpected error has occurred: No such addin configuration "ACT".
System.ArgumentException: No such addin configuration "ACT".
  at Ansys.Core.Addins.AddinConfigReader.d__12.MoveNext()
  at Ansys.Core.Addins.AddinManager.LoadFromConfigReader(AddinConfigReader reader, String config, String baseDir)
  at Ans.Program.Runtime.LoadAddins(RuntimeSettings settings)
- The topic ‘19.1 – Error message when opening Workbench’ is closed to new replies.
5679
1890
1419
1305
.jpg?width=690&upscale=false)
