Import .sat Data in pyANSYS
    • tim.hertinger
      I have a problem while importing a .sat file into pyANSYS by the following way:
      from ansys.mapdl.core import launch_mapdl
      mapdl = launch_mapdl()
      from ansys.mapdl.core import examples
      # note that this method just returns a file path
      bearing_file = "C:/Users/HertingerT/Desktop/Gestufte Lagerung/33213.sat"
      mapdl.aux15()
      mapdl.satin(name="bearing", extension=".sat" ,path=bearing_file, entity="ALL", fmt="1")
      print(mapdl.geometry)
      mapdl.vplot(vtk=True)
      mapdl.exit()
      Is there a general problem with the code or is that related to the .sat file?
      Here is the output in pyANSYS:
      MAPDL Selected Geometry
      Keypoints:  0
      Lines:      0
      Areas:      0
      Volumes:    0
      Thank you,
      Tim
    • ErKo
      Hi
      Can you post this in the pymapdl forum below as this might be a limitation or issue.
      https://github.com/ansys/pymapdl/issues
      Erik
    • tim.hertinger
      Hi Erik,
      thanks for your reply.
      I´ve also tried to remove the whitespace in the folder directory but that doesn´t help to solve the problem.
      I will post that issue in the pymapdl forum as well.
      BG
      Tim
    • ErKo
      Hi
      There is a post there from our team with some suggestions on how to use the command (so ‘file’ can not have the .sat extension in it) https://github.com/ansys/pymapdl/issues/2285
      Use the below code that works:
      filepath = ‘C:\\Users\\HertingerT\\Desktop\\GestufteLagerung’
      file = ‘33213’ # no .sat extension here!
      #### Launch pymapdl
      mapdl = launch_mapdl(run_location= here,override=True)
      mapdl.aux15()
      mapdl.satin(name = file , extension = ‘sat’,  path = filepath, entity = ‘ALL’, noan = 0)
      mapdl.allsel()
      mapdl.vplot()
      mapdl.exit()
  • The topic ‘Import .sat Data in pyANSYS’ is closed to new replies.
