Ansys Learning Forum Forums Discuss Simulation Electronics Magneto-resistive sensor for gear tooth sensing Reply To: Magneto-resistive sensor for gear tooth sensing
mohammedlaminemekhalfia
I tried but It was too complicated for me as my geometry is not symetrical so it was kind costy to make this simulation.
I tried to use maxwell because of the availability of example and possibility to perform this type of sim both on static and transient cases.
this is the example I was following
https://www.ozeninc.com/wp-content/uploads/sites/2/2015/05/sensors-for-automotive-applications-13416.pdf
I think thatI have to add a winding region inside the sensor vaccum where I assign an external circuit (I am not sure if I am correct).
