August 27, 2023 at 11:31 am
Atul Malge
SubscriberI want to run multiple test cases in Ansys fluent, for which I am importing a 2D step file from Solidworks. I want to know a way so that while running subsequent test cases in fluent with minor changes in the geometry I need to create the Named selections, and Boundary conditions again and again.
August 28, 2023 at 3:18 pm
Sunil Lilhare
Ansys EmployeeHello, if you want to automate the workflow of meshing and simulation for slight changes in the CAD, you can use parametric study of Ansys Workbench.
To know more about how to use parameters in Ansys Workbench, please refer to the link of a section of Ansys Fluent's User Guide given below.Working with Parameters and Design Points (ansys.com)
"If you are not able to access the link, please refer to this forum discussion: How to access the ANSYS Online Help
- The topic ‘Multiple test case query’ is closed to new replies.
