How does ANSYS FLUENT model the surface tension in the Eulerian (multi-fluid) model?
    • mohamedh
      I am using ANSYS FLUENT to model a two-phase flow of liquid and gas using the Eulerian model where the surface tension force is included.
        In the theory of the VOF model, the surface tension force is added to the momentum equation as a source term.   However, in the Eulerian model, we have two momentum equations, one for the liquid and one for the gas.
      How is the surface tension force included? is it added to the liquid momentum equation?is it added to the gas momentum equation? is it split between the two phases?   If it is split, is it split by two volume averaged factors or two mass averaged factors?
      Unfortunately, the theory manual does not mention related information under the Eulerian model theory.
    • DrAmine
      Give me some more time for reflection and I will get back to you!
    • mohamedh
      Thanks for your interest. I would be very thankful for you if you could help me.
    • DrAmine
      It is just multiplied with the volume fraction of the phase and applied for each momentum equation set of each phase. So if you add both momentum equations set for two phase flows you will end up with the source term applied for the bulk (like in VOF method). Please bear in mind that as ANSYS Stuff I cannot provide more information about the implementation on this open community.
    • mohamedh
      Thank you so much. That answers my question. That means it is split by two volume averaged factors.
      I appreciate your help a lot. Thanks
    • Mohammed OUALLAL
      You can not find anywhere the surface tensioin in Navier-Stockes equations. In terms of forces, you have body forces and volumetric forces (they are balanced with the acceleration in N-S). Surface tension is related to linear forces, which is related to boundary conditions.
      If you wanted to include surface tension for instance for a bubble ascending in a water pool, just use Young-Laplace equation to get your surface tension.
      You will find surface tension in the multiphase models, these add terms into the core solver equations which are based on NS equations.
Viewing 6 reply threads
  • The topic ‘How does ANSYS FLUENT model the surface tension in the Eulerian (multi-fluid) model?’ is closed to new replies.
