August 21, 2023 at 3:22 pm
Mehdi Feizpour
SubscriberHello,
I am getting this error: #LumApiError: 'no import objects are currently selected' when trying to import a text file as a surface using "#importsurface" command in #FDTD.
I can #import the #surface using the GUI but when I try to use #Python, this error pops up in the terminal.Â
Any as to what is causing this error woudl be appreciated as I did not find anything online.Â
August 21, 2023 at 3:57 pm
Mehdi Feizpour
SubscriberApparently, before importing a surface, you have to make an import object by fdtd.addimport()
I accidentally came across this webpage: https://optics.ansys.com/hc/en-us/articles/360034404154-addimport -
August 21, 2023 at 8:43 pm
Guilin Sun
Ansys EmployeeThank you Mehdi Feizpour for the reply. You are correct.
- The topic ‘LumApiError: ‘no import objects are currently selected’’ is closed to new replies.
1305
