August 30, 2018 at 10:56 pm
cjeong
SubscriberObjective of our project: Try to bend 3D object for E field simulation using wave port.
What we tried so far:
1) Simulate with 3 D object for E field simulation.Â
2) We bent the 2D antenna using wrap sheet function.
3) Then we add the thickness of the wrap sheet function, but the antenna disappears from the work space and the object changes from solids to unclassified.
Is there any other ways we can bend 3D object so that we can simulate for the E field?
Do you know when we try to add the thickness to the curved antenna, it disappears and changes from solids to unclassified?
cjeong
SubscriberThank you so much in advance!
September 18, 2018 at 4:20 pm
pgl
Ansys EmployeeBumping this up for better visibility. I've also moved it to our Electromagnetics category, and added some tags.Â
We'll get you an answer ASAP - You've been very patient. Â
September 18, 2018 at 5:57 pm
madhikar
Ansys EmployeeAre you getting any error message when you try to thicken the sheet? The error message generally tells the reason why its unable to thicken sheet. If you post the error message, that would be helpful. Â
September 20, 2018 at 11:30 pm
cjeong
SubscriberI was able to solve this problem. The issue was that I should wrap the antenna to the cylinder first, and then add thickness to the antenna.Â
Thank you so much for all your help!
September 21, 2018 at 1:37 am
pgl
Ansys EmployeeSuper. I'm thrilled that your problem has been solved.Â
- The topic ‘Curved spiral antenna simulation’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1220
1118
1015
