August 17, 2023 at 6:56 am
Robert Mehlig
SubscriberHi,
I am simulating lamb waves in CFRP plates/structures. For a 500x500x2mm plate I wanted to do a series of measurement at points placed every 0.5mm in a line. The motivation is doing a 2D FFT from (x, t) -> (k, f) to see which modes are present and if it fits with analytical & experimental results. I am running into a problem though:
I only want to store the timeseries for the required points. I therefore add all the points to a named selection so that I can see which nodes they correspond to. They happened to be 436 points, corresponding to nodes 1587 to 2022, see below:
/com,*********** Send Named Selection as Node Component ***********
CMBLOCK,FFT_2D_436POINTS,NODE, Â Â Â 436
(8i10)
   1587    1588    1589    1590    1591    1592    1593    1594
   1595    1596    1597    1598    1599    1600    1601    1602
   1603    1604    1605    1606    1607    1608    1609    1610
   1611    1612    1613    1614    1615    1616    1617    1618
   1619    1620    1621    1622    1623    1624    1625    1626
   1627    1628    1629    1630    1631    1632    1633    1634
   1635    1636    1637    1638    1639    1640    1641    1642
   1643    1644    1645    1646    1647    1648    1649    1650
   1651    1652    1653    1654    1655    1656    1657    1658
   1659    1660    1661    1662    1663    1664    1665    1666
   1667    1668    1669    1670    1671    1672    1673    1674
   1675    1676    1677    1678    1679    1680    1681    1682
   1683    1684    1685    1686    1687    1688    1689    1690
   1691    1692    1693    1694    1695    1696    1697    1698
   1699    1700    1701    1702    1703    1704    1705    1706
   1707    1708    1709    1710    1711    1712    1713    1714
   1715    1716    1717    1718    1719    1720    1721    1722
   1723    1724    1725    1726    1727    1728    1729    1730
   1731    1732    1733    1734    1735    1736    1737    1738
   1739    1740    1741    1742    1743    1744    1745    1746
   1747    1748    1749    1750    1751    1752    1753    1754
   1755    1756    1757    1758    1759    1760    1761    1762
   1763    1764    1765    1766    1767    1768    1769    1770
   1771    1772    1773    1774    1775    1776    1777    1778
   1779    1780    1781    1782    1783    1784    1785    1786
   1787    1788    1789    1790    1791    1792    1793    1794
   1795    1796    1797    1798    1799    1800    1801    1802
   1803    1804    1805    1806    1807    1808    1809    1810
   1811    1812    1813    1814    1815    1816    1817    1818
   1819    1820    1821    1822    1823    1824    1825    1826
   1827    1828    1829    1830    1831    1832    1833    1834
   1835    1836    1837    1838    1839    1840    1841    1842
   1843    1844    1845    1846    1847    1848    1849    1850
   1851    1852    1853    1854    1855    1856    1857    1858
   1859    1860    1861    1862    1863    1864    1865    1866
   1867    1868    1869    1870    1871    1872    1873    1874
   1875    1876    1877    1878    1879    1880    1881    1882
   1883    1884    1885    1886    1887    1888    1889    1890
   1891    1892    1893    1894    1895    1896    1897    1898
   1899    1900    1901    1902    1903    1904    1905    1906
   1907    1908    1909    1910    1911    1912    1913    1914
   1915    1916    1917    1918    1919    1920    1921    1922
   1923    1924    1925    1926    1927    1928    1929    1930
   1931    1932    1933    1934    1935    1936    1937    1938
   1939    1940    1941    1942    1943    1944    1945    1946
   1947    1948    1949    1950    1951    1952    1953    1954
   1955    1956    1957    1958    1959    1960    1961    1962
   1963    1964    1965    1966    1967    1968    1969    1970
   1971    1972    1973    1974    1975    1976    1977    1978
   1979    1980    1981    1982    1983    1984    1985    1986
   1987    1988    1989    1990    1991    1992    1993    1994
   1995    1996    1997    1998    1999    2000    2001    2002
   2003    2004    2005    2006    2007    2008    2009    2010
   2011    2012    2013    2014    2015    2016    2017    2018
   2019    2020    2021    2022My next thought was to add them seperately as named selections so that I can call them in "Outres" later. This was done as such (ChatGPT was a great help here...?),
CMBLOCK,P0,NODE, Â Â Â 1
(8i10)
   1587
CMBLOCK,P1,NODE, Â Â Â 1
(8i10)
   1588   Â
CMBLOCK,P2,NODE, Â Â Â 1
(8i10)
   1589
CMBLOCK,P3,NODE, Â Â Â 1
(8i10)
   1590
CMBLOCK,P432,NODE, Â Â Â 1
(8i10)
   2019
CMBLOCK,P433,NODE, Â Â Â 1
(8i10)
   2020
CMBLOCK,P434,NODE, Â Â Â 1
(8i10)
   2021
CMBLOCK,P435,NODE, Â Â Â 1
(8i10)
   2022Then I call them in Outres as,
outres,erase
outres,all,none
outres,nsol,all,P0
outres,nsol,all,P1
outres,nsol,all,P2
outres,nsol,all,P3
...However, in the output file it reads:
*** WARNING *** Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â 459.450 Â TIME= 16:49:28
 The number of output control specifications exceeds the maximum     Â
 allotted number of 50.  The OUTRES command is ignored.   ÂAny idea how I can circumvent this?
I extract the data from the ".rst" file using the "ansys.dpf" Python3 module. The code is as follows:
from ansys.dpf import post
from matplotlib import pyplot as plt
simulation_file = rf'C:\Users\rmehlig\Desktop\HPC_simulations\Simulation_files\{sim_identifier}_pwd\{sim_identifier}.rst'
simulation = post.load_simulation(simulation_file, simulation_type='transient mechanical')
P0 = simulation.displacement(all_sets=True, components=["Z"], named_selections=["P0"])
P1 = simulation.displacement(all_sets=True, components=["Z"], named_selections=["P1"])
plt.plot(P0)Thanks in advance,
Robert
August 17, 2023 at 11:26 am
Chandra Sekaran
Ansys EmployeeThe outres command can be issued only 50 times "You can issue up to 50 output-control commands for OUTRES, OUTPR, OUTGEOM in an analysis. "
For all components you seem to have set 'outre,nsol,all' . So why not combine all that into one outres command. You can use CMSEL to select all the components; create a new combined component and then issue one OUTRES like below?
cmsel,s,p0
cmsel,a,p1
cmsel,a,p2
cmsel,a,p435
CM,COMBINED,node
OUTRES,NSOL,ALL,COMBINED
August 17, 2023 at 1:36 pm
Robert Mehlig
SubscriberThank you, I will try this if the following doesn't work. I thought since I know the node ID's I can simply call these instead of the named selection. I do however not want to save all nodal solutions, therefore I access this through defining a named selection of all wanted points:
(8i10)
   2019    2020    2021    2022Then I call it in the "outres" command:
outres,erase
outres,all,none
outres,nsol,all,FFT_2D_436POINTSSince they nodes are defined I might be able to call them later. I just hope the node index doesn't change in the result file...
August 21, 2023 at 2:37 pm
Robert Mehlig
SubscriberÂ
Dear Chandra Sekaran,
My idea did not work, neither did yours. Yours produces the error message:
*** WARNING *** Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â Â 29.724 Â TIME= 16:32:22
 Node 312 on element 1 is unselected.    Â
 *** WARNING ***             CP =    29.730  TIME= 16:32:22
 Node 248242 on element 25 is unselected.                Â
 The number of ERROR and WARNING messages exceeds 200.          Â
 Additional messages suppressed.  See (                 Â
 /home/rmehlig/ANSYS_sim/T1_40Waveplate_v4_2023-08-21_16-31-57_pwd/T1_40Â
 0Waveplate_v4_2023-08-21_16-31-57_0.err ) for suppressed messages.   Â
 ALL CURRENT MAPDL DATA WRITTEN TO FILE NAME= ansabort.db
 FOR POSSIBLE RESUME FROM THIS POINT
 The number of ERROR and WARNING messages exceeds 10000.         Â
 Use the /NERR command to increase the number of messages.       Â
 The ANSYS run is terminated by this error.               Â
************************************************************************Any idea? Thanks in advance,
Robert
August 21, 2023 at 5:19 pm
Chandra Sekaran
Ansys EmployeeIt looks like not all nodes are selected when you issue solve command. Add a ALLSEL command like below at the very end.
cmsel,s,p0
cmsel,a,p1
cmsel,a,p2
cmsel,a,p435
CM,COMBINED,node
ALLSEL
August 22, 2023 at 7:46 am
Robert Mehlig
SubscriberThis means that it solves for all nodes, but only stores the nodes in the "COMBINED" group?
Robert Mehlig
SubscriberDoes capitalization matter when calling the named selections?
August 22, 2023 at 10:39 am
Robert Mehlig
SubscriberÂ
So like this?
cmsel,a,P425
cmsel,a,P426
cmsel,a,P427
cmsel,a,P428
cmsel,a,P429
cmsel,a,P430
cmsel,a,P431
cmsel,a,P432
cmsel,a,P433
cmsel,a,P434
cmsel,a,P435
CM,POINTS_COMBINED,node
outres,erase
outres,all,none
outres,nsol,all,POINTS_COMBINED
ALLSEL
! *********** WB SOLVE COMMAND ***********
! check interactive state
*get,ANSINTER_,active,,int
*if,ANSINTER_,ne,0,then
/eof
*endif
solve
/com *************** Write FE CONNECTORS *********Â
CEWRITE,file,ce,,INTE
/com,****************************************************
/com,*************** FINISHED SOLVE FOR LS 1 *************
/com,******************* SOLVE FOR LS 2 OF 2 ****************
/com,*********** Set Force Without Surface Effect Elements "T1 Pin" ***********
sfedel,_CM187_3,3,pres,all
sfedel,_CM187_4,4,pres,all
sfedel,_CM187_5,5,pres,all
sfedel,_CM187_6,6,pres,all
nsel,all
esel,all
/nopr
/gopr
autots,off         ! User turned off automatic time stepping
deltim,8.333e-007,8.333e-007,8.333e-007
time,7.5e-004
timint,on          ! Turn on time integration effects
outres,erase
outres,all,none
ALLSEL
solve
/com,************ FINISHED SOLVE FOR LS 2 **********Â
August 22, 2023 at 1:33 pm
Chandra Sekaran
Ansys Employeeyes
August 22, 2023 at 1:40 pm
Chandra Sekaran
Ansys EmployeeThis means that it solves for all nodes, but only stores the nodes in the "COMBINED" group?
Yes, solves the entire model but writes results only for the component specified in OUTRES command
No, capitalization does not matter. CMSEL,S,COMP1 is same as CMSEL,S,comp1
- The topic ‘APDL Outres Limitations’ is closed to new replies.
