August 27, 2018 at 1:26 am
Joseph Lim
SubscriberDear community,
Attached is the error that I encounter when I start to open the mechanical and geometry editor. May I ask for some suggestions and help with those problems?
Thank you very much in advance.Â
Joseph
August 27, 2018 at 2:32 am
peteroznewman
SubscriberIs the problem you are asking about that there are no tools in the toolbox?
For the toolbox issue, I assume you have tried a restart on your computer.
Is the license local to that machine or is there a license server that machine needs to communicate with?
August 27, 2018 at 5:49 am
Joseph Lim
SubscriberHello Peter,
Yes, I have a problem with the toolbox issue. I have tried to restart on my computer numbers of times but I still have the similar problem.
I think is a license server that machine needs to communicate with.
Joseph
August 27, 2018 at 5:59 am
Bhargava Sista
Ansys EmployeeJoseph,Â
Try these steps:
- Close all open WB sessions.
- In Run, type %appdata%, this will open the Roaming folder. Open the folder named Ansys.
- Since you're using version 14.5, look for a folder named v145. Rename it as v145_old.
- Now open a new WB session, see if this resolves the issue.
Let us know if that helps, cheers!
August 29, 2018 at 12:37 am
Joseph Lim
SubscriberHi Bsista,
Thanks for the suggestion. I had tried using other approaches which I reinstall the software (Ansys Workbench 14.5). The problems solved after I reinstall the software.
Cheers!
JosephÂ
March 25, 2021 at 4:33 pm
- The topic ‘Unable to start the mechanical and geometry editor in Ansys workbench 14.5’ is closed to new replies.
6094
