Ansys Products
Ansys Products
file directory option
    • KumarVaibhav
      i have observed that using ansys is occupying my C drive like anything so i changed the permanant and temporary file locations to D and E see the screenshot but my software is malfunctioning i think?Pls explain if i willl be able to open my old files with the default settings as before
    • Sandeep Medikonda
      How is it malfunctioning? Please explain.
      How much disk space are you talking about? Can you provide some numbers of the drive and your computer specifications?
      Lastly, are you working off a saved file or an unsaved file?
    • KumarVaibhav
      i have a 250 Gb SSD drive in c and 1TB in D and E.it Is i7  processor with 32gb ram with windows 8.1 x64
      yes i am working with unsaved file often
    • Sandeep Medikonda
      Ok So, save the workbench file on the D drive, i.e., the wbpj file, close an open or restart the computer even. I am guessing that the %appdata% environment variable is not updated.
      As a check see where
      %appdata%ansys
      points to when you open that location in a file manager or a command prompt?
      Sandeep
    • KumarVaibhav
      sandeep can u tell me why i am not getting the green ticks after solving the model i instead get these green download sort of symbols due to which i am not able to view the solution parameter outputs.How should i restore my settings default ones back?pls help see the screenshot
    • Sandeep Medikonda
      It means a successful background solution that is ready for download. Please see this section of the manual.
      Sandeep
Viewing 5 reply threads
  • The topic ‘file directory option’ is closed to new replies.
